Author Topic: Siglent SVA1032X programing  (Read 1908 times)
Offline siglentLearnerTopic starter
« on: May 30, 2022, 03:38:04 am »
I have connected the Siglent SVA1032X network analyzer to a PC with a LAN cable.
I have a .csv file saved in the instrument using the following SCPI command:
fprintf(siglent,'MMEM:STOR CSV, ,"TEST.csv")
I need to transfer it to my local PC connected to it by LAN.
If I have connected a USB to the instrument how can I save the file 'TEST.csv' to the USB file path? :-//
Thank you for your help.  :)
Regards
M
Offline Bicurico
  • Country: pt
  • Broadcast Systems & Transport Stream Analysis
    • VMA-Broadcast
Re: Siglent SVA1032X programing
« Reply #1 on: May 30, 2022, 09:49:25 am »
Why don't you use SCPI commands of the Siglent SVA1032X to send you the data directly through LAN/USB, instead of first writing it to a file in local memory?
The following users thanked this post: Meestor_X
Offline Meestor_X
« Reply #2 on: October 26, 2022, 09:43:26 pm »
What is the command to receive the data and how is it formatted?
Offline Bicurico
  • Country: pt
    • VMA-Broadcast
« Reply #3 on: October 27, 2022, 07:08:23 am »
You need to read the SCPI manual that Siglent has for download
I developed a whole software for the spectrum part and it was straight forward to receive data and set parameters by just using the documentation.
Since I don't own the Plus/SVA version I did not bother with specific functionality of these models.
