Author Topic: Tl866 prom programmer bricked, Intel 2716  (Read 2565 times)
Offline jonpaulTopic starter
  • Analog, magnetics, Pwr high voltage, Audio, Cinema
    • IEEE Spectrum
« on: February 14, 2020, 04:59:50 pm »
Bonjour à tous,
Years ago I bought the MiniPro Tl866 programmer, and used it for years mainly with the Dallas Semi NVRAM.
Today I had to read the code of a 1977 cipher machine, an Intel 2716, but the reader fails to see the prom.
Same with other similar parts.
I made the mistake of updating the firmware!
Now its bricked "pirated" serial not valid" even though it is the genuine original model.
I found the proceedure  to  update to the tl866A version, same result.
Seems like a Chinese scheme to brick old units abd generate new sales?
Any assistance appreciated, as the programmer is urgently need for some historic research of my non-profit organization.
Perhaps just a valid serial number? Or defective update file?
Mille mercis pour votre gentil aide !
Jean-Paul
The Internet Dinosaur..
passionate about analog electronics since 1950s
Offline kripton2035
« Last Edit: February 14, 2020, 05:14:47 pm by kripton2035 »
    • IEEE Spectrum
Re: Tl866 prom programmer bricked, Intel 2716
« Reply #2 on: February 15, 2020, 09:40:12 am »
Hello Kripton: Many thanks I am NOT a software maven and last programmed in 1964 on IBM 360, Fortran II!
As I have the MiniPro and the HW is fine, I am looking for any one else with this device and any possible solutions. Lots of others have the same issues, as its $50 and very popular.
Kind Regards,
Jon
Offline kripton2035
« Reply #3 on: February 15, 2020, 10:28:37 am »
did you try the "dangerous method" of this post : https://www.eevblog.com/forum/blog/eevblog-411-minipro-tl866-universal-programmer-review/msg383943/#msg383943
did you also try the method (some posts after) with soldering a resistor to force update mode ?
Offline kripton2035
« Reply #4 on: February 15, 2020, 10:32:46 am »
you can also use this : https://github.com/radiomanV/TL866
there is a method to generate a new serial.
