Can I use this kind of "cheap" video Serial Digital Interface (SDI) splitter/distributor box to distribute the reference 10MHz signal from the GPSDO board ?
Example at Aliexpress -> Cheap SDI splitter
No affiliation with seller, just searched for "sdi splitter", choose the one with 4 outputs and sorted by price. [emoji14]
Click to enlarge photos.
Btw, what is that "Lock" LED indicator for ?
"Lock" led could indicate that this is SDI digital regenerator, thus not compatible with 10MHz signal distribution.
You shall search not "SDI splitter" but "composite video splitter BNC".
Like this random google hit:
http://www.thesmarte-mart.com/ProductDetails.asp?ProductCode=SB-3701BNC
I am in the process of building a 10MHz reference source for my lab. It's based on a pretty stable OCXO and an Extron video amplifier. I believe there are other people on the forum we did use such a device to achieve the same goal.
The main point to be aware of is the fact these are generally 75ohm. Whether you want to fix that or not is up to you. Not sure what are the real drawbacks of keeping as is, for a 10MHz signal it should not be such a big deal.
In my ref source, I'll also include a rubidium source I purchased years ago (an Efratom LPRO 101) for calibration purpose or when I need really a precise 10MHz signal.
Envoyé de mon GT-N7105 en utilisant Tapatalk
