Hi everyone, first-time PCB designer here. Simple 2-layer carrier board
for XIAO ESP32-C6, designed in KiCad 10, targeting JLCPCB assembly.
Reads DS18B20 sensors via 1-Wire, 0.8–3m unshielded flat cable (1.2mm
silicone). Environment can be electrically noisy and cables get handled
regularly, so I went heavy on protection. Two JST PH 3-pin connectors
for sensors (both on one 1-Wire bus, addressed by ROM code). Board size
28×45mm.
Protection chain per channel (connector → MCU): ferrite 600Ω on VCC +
ferrite 600Ω on DQ → common-mode choke (ACM2012-900-2P) → TVS
(UCLAMP3301D) → shared DQ bus → USBLC6-2SC6 dual ESD → 4.7k pull-up →
XIAO GPIO.
2-layer ENIG, GND pour both sides, XIAO hand-soldered after PCBA
(castellated pads). USB-C power only.
I'd appreciate a review — worried about EMC filtering on the unshielded
cables, ESD protection approach, and any rookie layout mistakes. Is a
snap-on ferrite toroid on the cable at enclosure exit a reasonable
fallback if EMC pre-scan shows issues?
Schematic, 3D render and copper layer attached.
BOM:
100nF - C1 C3 C4 - 0805 - C49678
10µF - C2 - 0805 - C15850
1µF - C5 - 0805 - C28323
600Ω Ferrite - FB1-FB4 - 0805 - C1017
4.7kΩ - R1 - 0805 - C17673
UCLAMP3301D - TVS1 TVS2 - SOD-323 - C5199861
ACM2012-900-2P - CM1 CM2 - 0805 CM - C145854
B3B-PH-SM4-TB - J1 J2 - JST PH - C160353
USBLC6-2SC6 - U2 - SOT-23-6 - C2687116
