i am trying to get a 10MHZ sign wave distributed to four outputs. i have few op amps at my disposal which i would like to use, these include: MC33282,AD841,OPA627,MC34080,LM118.
now looking at the data sheet for these op amps i can see that almost all can handle frequency of at least 10MHZ, so i did a search on Google and used a non inverting op amp circuit as an buffer to get the signal out. but this does not work. connecting the scope to the out put of the op amp after 50 ohm resistor to ground and 50 ohm resistor to the out put give me a sign wave which does not look right but the counter on my scope says that it is 10MHZ. the wave is very small about 100mv Ptp and it does not look like the original signal.
the 10MHZ sign wave is generated via a oven controlled crystal oscillator. it uses 12 volts but the sign wave measures at 4.8v ptp.
can some one please help let me understand what i am doing wrong?
