This may be a bit odd, but has anyone seen a 1/4" TRS connector with a built-in LED? (Or like a three-pin variant of a Dell laptop power adapter with that glowing blue ring on the DC plug hood?)
I'm designing a new model rocket launch controller for the Cub Scouts. Thinking of how to make removable "keys" that also indicate circuit status....and also harder to spoof.
A 1/4" connector seems about the right size, not too small and easy to lose, but not too large and a pain to carry 16 at once.
Using a TRS/stereo type, so as to have both positive and negative sides of the circuit....and an extra contact in-between. If the Scout inserts the valid connector, we'll have the tip and sleeve wired together, and it'll work. But if they try sticking a pocket knife, wire, whatever into the jack; the tip will short to the ring and tell the controller to lock-out!
Don't know that I've seen such a connector, with an LED. But before I take on building one, thought I'd ask the community to share if they know of one. Or are there other ideas for such a removable circuit "key?" Thanks in advance.
