Author Topic: 1997 Buick VAT Bypass Circuit  (Read 1144 times)
Offline bostonmanTopic starter
« on: August 19, 2019, 02:28:53 am »
I have a question about the old "security" feature that uses a resistor in the key; I think it's called VAT.
Anyway, due to resistor tolerance, keys with the same resistor value can differ slightly.
Does anyone know what the tolerance of the resistor pellet? Also, I assume the car uses a comparitor circuit to compare a set value. How does it handle both upper and lower limits of the tolerance values?
I'm thinking maybe it's not hardware like a comparitor, but maybe software that handles a range of values to handle the variations.
Online bdunham7
Re: 1997 Buick VAT Bypass Circuit
« Reply #1 on: August 19, 2019, 03:27:42 am »
3% according to this source.  I remember bypassing them (no, I'm not a car thief...) and using cheapo resistors that were probably 5% tolerance at best and not having issues.  The resistances were far enough apart that tolerances didn't matter too much--you just had to select the right key.  And I never had a key not work for being out of tolerance, although I rarely if ever measured the NEW keys.
https://www.lockmasters.com/site/pdfs/TT4002%20Vats%20Overview%20Article.pdf
« Last Edit: August 19, 2019, 03:33:49 am by bdunham7 »
« Reply #2 on: August 19, 2019, 12:52:00 pm »
I had an old car where this system died and then had the whole key assembly replaced. Months later the system went bad again, and, not realizing how simple the system was, returned to the mechanic. He found the resistor pellet went bad, either because it went out of tolerance or opened. Unfortunately I don't know what happened, but know the second time it was just the key.
Now I have an old car and decided to by pass the resistor pellet because I sense it will eventually fail. To match the value, and having a limited amount of resistor values, I used two in parallel with one in in series. It's about a 20 milli-ohm difference using 1% resistors.
I was a bit concerned working around the yellow air bag wire because I don't know what it takes to trigger it, but have read banging the wire isn't good. I had the battery disconnected, but remained cautious regardless.
Wish I didn't get intimidated by the "high tech" security system because I blew a chunk of time/money having the mechanic fix it for me. I don't remember the cost, but paid for a tow (this was before AAA), paid for the repair, and then months later got stuck in downtown Boston late night. Since the repair was still under warranty, got the car towed to his shop (which he paid for), but wasted a whole night trying to get home. For the cost of a few resistors, I could have saved time/money.
Offline amyk
« Reply #3 on: August 20, 2019, 01:10:02 am »
The title of this thread reads far more curiously to someone from Britain... I was expecting something less legal :o
