Author Topic: 2.2uF C0G/NP0  (Read 4165 times)
Offline fabiodlTopic starter
2.2uF C0G/NP0
« on: October 28, 2019, 02:14:11 am »
I am developing a board around the TI pcm5122.
The datasheet at page 66 reports that all caps should be 2.2uF C0G.
I cannot find any caps with that dielectric/temperature coefficient on Digikey with capacitance over 560nF.
Do bigger C0G caps exist? What/Where should I search for?
« Last Edit: October 28, 2019, 04:07:30 am by fabiodl »
Online langwadt
Re: 2.2uF C0G/NP0
« Reply #1 on: October 28, 2019, 02:17:20 am »
use 4?
Offline DaJMasta
    • medpants.com
Re: 2.2uF C0G/NP0
« Reply #2 on: October 28, 2019, 03:18:13 am »
I'd be sort of surprised if they do, I'm actually surprised you can find a 500nF C0G, the ones I'm used to seeing top out in the single digits.
Why not a film cap instead?
Offline Jay_Diddy_B
Re: 2.2uF C0G/NP0
« Reply #3 on: October 28, 2019, 03:23:33 am »
I think is a an error the correct value is 2.2nF
They use 2.2nF in other places in the documentation.
2.2nF and 470 \$\Omega\$ is 153kHz
2.2uF and 470  \$\Omega\$ is 153 Hz low pass filter.
Jay_Diddy_B
The following users thanked this post: I wanted a rude username
Offline duak
Re: 2.2uF C0G/NP0
« Reply #4 on: October 28, 2019, 03:26:59 am »
Wow, I'm surprised there are even 560 nF parts.  I think it's a mistake.  The output filter should be 2.2 nF C0G as per the schematic, while the 2.2 uF for the charge pump can be an X7R.
Here's a link to someone who thinks the same: https://electronics.stackexchange.com/questions/386216/pcm512x-charge-capacitor-value
Online floobydust
Re: 2.2uF C0G/NP0
« Reply #5 on: October 28, 2019, 03:30:53 am »
Na, it's several typo's. There are no C0G/NPO's that big and you would not put something so huge at the DAC's outputs.
Those are properly 2.2nF C0G?, and 2.2uF X7R are used for the charge-pump. Look at PCM5122 Evaluation Module http://www.ti.com/tool/PCM5122EVM-U
Offline BravoV
  • +++ ATH1
Re: 2.2uF C0G/NP0
« Reply #6 on: October 28, 2019, 03:38:15 am »
A 100nF C0G/NPO is about 24 dollars a pop  :o , example -> Kemet C0G Cap
I can't imagine what will be the price if at 2.2uF.   :scared:
« Last Edit: October 28, 2019, 03:40:45 am by BravoV »
Re: 2.2uF C0G/NP0
« Reply #7 on: October 28, 2019, 04:11:05 am »
Thank you very much everybody.
The evaluation board's schematic/bill of materials really helps a lot, it was a typo indeed!
Offline exmadscientist
  • Technically A Professional
Re: 2.2uF C0G/NP0
« Reply #8 on: October 28, 2019, 05:16:51 am »
Huh? No they're not. I've used a bunch of 100nF NP0 caps when I need stability and it's not worth expending more design effort to use something cheaper. They're usually about a quarter, like GRM31C5C1E104JA01L at US$0.23 in quantity 100.
It also looks like Kemet has recently introduced a new NP0 line that's about a factor of 5 cheaper, but they're not stocked at distributors yet. (Example part at Mouser.)
Offline BravoV
  • +++ ATH1
Re: 2.2uF C0G/NP0
« Reply #9 on: October 28, 2019, 05:19:08 am »
Yeah, you're right, those I pointed out is for 100V rated.  :scared:
Offline MagicSmoker
Re: 2.2uF C0G/NP0
« Reply #10 on: October 28, 2019, 09:45:15 am »
Since the OP's question has been answered, note that there are C0G caps rated for up to 330n and 100V that only cost $5.78 on Mouser:
https://www.mouser.com/ProductDetail/KEMET/C2220C334J1GACTU?qs=sGAEpiMZZMs7ZEmUmaUL0%252BHfn%252BkysyX5xyIpm1WOce8%3D
Offline ZaphodBeeblebrox
Re: 2.2uF C0G/NP0
« Reply #11 on: October 29, 2019, 05:38:34 pm »
Replace with polymer caps. Only better, nothing worse, at least for audio DC blocking.
There is this thing about leakage current you might want to consider...
Re: 2.2uF C0G/NP0
« Reply #12 on: October 30, 2019, 12:57:47 am »
It is "funny" that in their schematic/bom they use x7r and not c0g even for the low pass output filter
Online floobydust
Re: 2.2uF C0G/NP0
« Reply #13 on: October 30, 2019, 05:52:12 am »
It's better C0G as they have lower dielectric absoption, critical in say a reconstruction filter, but not as much here because the DAC's output impedance and 470R resistor work around it.
Signal distortion from high-K ceramic capacitors
Maxim AN4333 only looks at X7R, Y5V and the low freq. <300Hz gets badly distorted.
The eval boards are usually to play with developing S/W and few have test results showing it actually achieves 24-bit resolution with low noise. +3.3VA also powers the DAC IC's
VD digital portion which might not be ideal.
