Author Topic: 2.4GHz radio control protocol?  (Read 5071 times)
Offline deephavenTopic starter
  • Civilization is just one big bootstrap
    • Deephaven Ltd
« on: August 19, 2011, 01:07:02 pm »
I notice that a lot of radio control model aircraft etc now use 2.4GHz rather than the lower frequencies. Does anyone know if they use a standard protocol like Zigbee or similar or is there one dedicated to that application? Just curious.
Offline kaptain_zero
Re: 2.4GHz radio control protocol?
« Reply #1 on: August 20, 2011, 03:32:24 am »
They still use PCM (pulse code modluation) but proprietary spread spectrum transmissions. No two manufacturers equipment is compatible. Notable exception is JR/Spektrum who share their technology as far as I know.
Regards
Christian
    • Deephaven Ltd
« Reply #2 on: August 21, 2011, 05:51:30 pm »
Thanks Christian.
Offline RCMR
« Reply #3 on: August 22, 2011, 12:47:11 am »
As Christian has said, there is no "standard" for the protocols used now that RC gear has gone to 2.4GHz.
In the old FM ("longwire) days, there was a defacto standard that involved the use of a pulsetrain (one for each channel) with a median width of 1.5mS and a variance of (usually) +/- 500nS.  Each frame (series of channel-pulses) was demarked by a sync pulse that was generally 3mS or longer, depending on the number of channels encoded.  The standard frame-rate was around 20mS (50 fps).
Now however, each manufacturer has come up with their own method for encoding the channel positions, each striving to produce the lowest-latency and highest redundancy.
None of these protocols are well documented -- since they're considered "proprietary" by most manufacturers.  However, a little work with a logic analyzer will likely reveal a whole lot.
The only systems that use existing standard base protocols (or did) are the XPS and (I think) the Jeti ones.  They are/were based on ZigBee.
