Author Topic: 200A BMS PCB stackup  (Read 1229 times)
Offline pmendiukTopic starter
« on: September 22, 2022, 02:28:37 pm »
Hey All,
I have been looking at various high current (200A) BMS and most of the manufacturers have little or no documentation or detailed specifications available on line.  I'm starting to consider designing my own and I've looked at some source down MOSFETs (Infineon IAUT300N10S5N015ATMA1 300A 0.15mOhm) and wondered about what kind of PCB stack ups are being used for these MOSFETs.  Some of BMS PCBs I've seen have bus bars sweated down on some of power paths but not all high current power paths have bus bars.  I assume the power paths are multilayer but the via stitching on those boards is not very dense.
Offline strawberry
  • Country: lv
Re: 200A BMS PCB stackup
« Reply #1 on: September 22, 2022, 03:21:13 pm »
most BMS protect only against cell undervoltage and/or overvoltage
with poor over current circuits
most of them use 1Mohm resistors to turn MOSFET on (low power consumption but MOSFET turns on slow/linear ) reason why they are so many in parallel
some use programmable fuel gauge or what not. need expensive programmer to set custom cell voltage and stuff
200A is serious design 14kW@70V
welding cables...
uneven current distribution over MOSFET...
« Reply #2 on: September 22, 2022, 04:01:53 pm »
Yes I agree serious design with those currents.  The various Chinese BMS I've looked at on line don't instill a lot of confidence.  I'm thinking about a latching contactor as an alternative but I'm still curious about how those MOSFETs are adequately connected to those bus bars through FR4.
Online nctnico
« Reply #3 on: September 22, 2022, 04:08:56 pm »
Wurth has high current PCB-to-busbar solutions but I would typically derate any such solution by 50% for real world use.
