Author Topic: 20W speaker amplifier  (Read 3778 times)
Offline Simon123Topic starter
  • Country: si
    • Youtube channel
« on: April 22, 2014, 06:18:56 pm »
Hello!
I kinda designed 20W speaker amp and would like, that somewhone would check it and point out the errors.
Base current of TR1=350uA, Ic=35mA
IB TR2= 35mA, Ic=1,78A
2n3055 collector resistor is to low value for power, il change that.
I realy dont care about current consumption, cuz i have 10A transformer and that shouldnt be big deal.
Is 2N3055 good for audio?
Is this designed properly for class A amplifier or AB, dont care ?
Thanks!
« Last Edit: April 22, 2014, 06:20:27 pm by Simon123 »
Offline T3sl4co1l
    • Seven Transistor Labs
Re: 20W speaker amplifier
« Reply #1 on: April 23, 2014, 12:16:55 am »
The first stage looks right, the second stage is suicide biased.  You cannot rely on hFE, it is a secondary parameter and varies by about 250% between different pieces of the same transistor type, different brands, and over temperature and operating current.
There are better ways to heat ones' home, ;)
Seven Transistor Labs, LLC
  • Country: si
    • Youtube channel
« Reply #2 on: April 23, 2014, 06:13:33 am »
Should i make it voltage divider then?
Offline peter.mitchell
« Reply #3 on: April 23, 2014, 08:49:54 am »
Is this project for learning or just to make a practical quick widget? if it's to make a quick practical widget, for the price of 3x 2n3055s you can buy a TDA7292 and you're almost done.
Offline wiss
« Reply #4 on: April 23, 2014, 08:56:13 am »
If you insist on going discrete, yes!
And an emitter-resistor on the power-transistor to somewhat control the gain and bias-current.
This will be a very good way to heat your home and spend money on heatsinks.
  • Country: si
    • Youtube channel
« Reply #5 on: April 23, 2014, 12:34:28 pm »
Its kinda for learning, so i can understand all on the circuit.
To understand some pushpull ic is more dificult if i dont understand this.
As heatsink il proably just use 3mm piece of aluminium.
Thanks for replying.
Offline madires
  • A qualified hobbyist ;)
« Reply #6 on: April 23, 2014, 12:58:12 pm »
One or two secondary taps? If it got two go for the classic push-pull approach. BTW, to calculate a proper input coupling cap please use f = 1 / (2 * pi * R * C). That's the lower frequency limit at -3dB (coupling cap plus input impedance creates a RC filter).
Offline wiss
« Reply #7 on: April 23, 2014, 02:00:04 pm »
Sure, go for lower power and it will work :)
a few sqaremeters?  >:D
  • Country: si
    • Youtube channel
« Reply #8 on: April 23, 2014, 04:16:37 pm »
OK, il calculate capacitors, this is just some aproximation i think should work.
I only have single sec. tap.
Il use fan for transformer in powerhouse also.
