Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
230v or 415v AC to 24v PSU
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 230v or 415v AC to 24v PSU (Read 2098 times)
andybarrett1
Regular Contributor
Country:
on:
November 05, 2015, 04:19:48 pm »
Hi All
Looking for a means of getting a decent 24v DC supply (low current) from 230 or 415AC
Have looked at using X2 cap/resistor/zener option but no isolation from mains which will be needed...
Wondering if can still use this method but then into a switch mode so using the switch mode as isolation
Just looking for ideas at moment .... Has to be small and cheap !
All ideas welcome !
Thank you for reading
Andy
Last Edit: November 05, 2015, 06:10:57 pm by andybarrett1
Logged
Paul Price
Super Contributor
Re: 230v or 415v AC to 24v PSU
Reply #1 on:
November 05, 2015, 06:52:57 pm »
The really important question here to offer a solution is for you to reveal what current you call low current?
Logged
andybarrett1
Regular Contributor
Country:
Reply #2 on:
November 05, 2015, 07:01:07 pm »
No more than 250mA... Maybe less than that.
A 4-20mA Loop
1 PIC Chip
2 PCB Mounted 5v Relays
3 Leds
As a start point !
TY
Andy
Logged
Paul Price
Super Contributor
Reply #3 on:
November 05, 2015, 07:08:16 pm »
You say the 24V power supply must work also using 415 RMS VAC power line input as well?
Otherwise, a transformer:
ABL6TS02B
SCHNEIDER ELECTRIC
Isolation Transformer, Phaseo Optimum, 25 VA, 1 x 230V, 1 x 400V, 24V secondary
Last Edit: November 05, 2015, 07:24:55 pm by Paul Price
Logged
station240
Supporter
Country:
Reply #4 on:
November 05, 2015, 07:18:55 pm »
You can use a Buck/Boost Inverter with a transformer instead of a coil.
That would give you the isolation at the output. Feed the inverter from the X2/resistor/zener supply.
Another option is to rewire/rewind a CCFL inverter that just has a transistor based driver.
Logged
andybarrett1
Regular Contributor
Country:
Reply #5 on:
November 06, 2015, 10:26:00 am »
Thanks for replies..
I also have a space constraint....
The board I want to mount this on has a size 90mm x 90mm.... And is already half populated with some logic and relays. I am aware I can use a transformer etc.... But that is not an option hence thinking about the Capacitor Drop... Not a Transformer !
Station240: Inverter / Buck Boosts are to step up usually ?
BR
Andy
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
