A TRIAC will typically drop around 1V, irrespective of the load current.
TRIACs are typically rated of hundreds of volts, whilst the peak voltage of your 24VAC power supply is only 34V, so you have plenty of headroom. I'd use a 470R resistor, in series with a 100nF capacitor, across either the TRIAC, or solenoid.
