Why would there be? The assumption ever since Philips came up with I2C is that there is a MCU or CPU 'in the loop' to handle configuration, so if it *is* possible to configure an I2C device to power up standalone in a particular selectable state, that configuration will be done over I2C .
If you *need* that functionality, you are probably going to have to roll your own I2C slave on a MCU or FPGA with enough I/O pins to let you have 'override' inputs.
