Author Topic: -30V Supply for diode  (Read 3252 times)
Offline slowertechTopic starter
« on: May 16, 2017, 04:19:06 pm »
I need to create a -30V voltage rail for a diode I want to use but I am having trouble creating that.
I have attached a schematic for something I had put together but I do not seem to be able to get it to output what I need, I am actually getting ~3V.
I had used the formula within the datasheet to figure out the value for R4 that I would need to get -30V.
Maybe someone will see something obvious that I have glossed over or has an alternative part I could try?
The part I am using is an LT1372HVCS8#PBF and the datasheet http://cds.linear.com/docs/en/datasheet/13727fbs.pdf
Thanks!
Offline Zero999
  • 0999
Re: -30V Supply for diode
« Reply #1 on: May 16, 2017, 05:03:09 pm »
That seems like an unusual thing to do.
What sort of diode is it?
Please post a schematic of what you're trying to power. It's possible there's an easier way to do this.
« Reply #2 on: May 16, 2017, 10:36:41 pm »
I have attached a schematic with how the circuit is set up.
The part is a Silicon Photomultiplier from SensL.
The part I am using is ArrayJ-60035?4P-EVB
http://sensl.com/estore/arrayj-60035-4p-evb/
The documentation for the part
http://sensl.com/products/j-series/
Offline daveshah
  • Country: at
    • Projects
« Reply #3 on: May 17, 2017, 08:40:12 am »
This was my SiPM bias circuit, if you're curious
See the full writeup here: https://ds0.me/sipm/index.html
« Last Edit: May 17, 2017, 08:42:53 am by daveshah »
Offline capt bullshot
« Reply #4 on: May 17, 2017, 11:38:48 am »
Does it work if you swap the output pins of the transformer?
The polarity isn't indicated in your diagram, must be correct for the circuit to work
« Reply #5 on: May 17, 2017, 02:15:39 pm »
daveshah,
Thanks that is awesome! I will actually look through that later today when I have down time later today.
capt bullshot,
I was looking at it early this morning and noticed I completely messed up the pin positions for the transformer, also noticed I did not have the part number in the schematic. Sorry about that.
The transformer is part: CLS62NP-100NC
I will correct it today and poke around with it a bit and update.
Thanks!
