I have a design where I need to dissipate 2.7 watts continuously through a bank of resistors (actually, I have 3 identical banks with similar loads). I have two choices:
- Use 3x 5W through hole resistors. At 900mW per element (They are physically very big).
- Use 10x 1W 2512 surface mount resistors. At 270mW per element.
(I have more than two choices, but I think the above are pretty similar)
I currently use the through hole resistors, but they are pretty bulky. This PCB (which is primarily SMT) currently has banks of through hole resistors for various functions. I am trying to evaluate if SMT 2512 resistors might be a viable alternative.
I want to keep the temperature rise low enough to not melt or soften cables, tape, etc. that may incidentally touch the PCB.
For a resistor bank like this which is preferable (SMT vs TH) to you and why?
Which can be made more reliable?
I think this device might be occasionally dropped down a concrete staircase. I wonder if the SMT resistors might crack.
SMT resistors tend to occupy a smaller area. They may have more trouble dissipating the heat. I suppose they could be spread out over the same area and alternately placed on both sides of the PCB. I almost feel that I might need to calculate surface areas.
I have trouble estimating temperature rise. I hope to achieve something roughly equivalent to the through holes.
They will be mounted on the edge of a PCB and allowed natural convection cooling inside of a large enclosure.
Image showing the size difference between the two schemes, and the approximate width of the PCB.
A possible way of arranging the 3 banks of SMT resistors
