Author Topic: Want to make a special resistor value out of series and/or parallel resistors ?  (Read 4973 times)
Offline ChipguyTopic starter
Hey folks
For the purpose of narrowing down 2 or more resistor values in order to make one special value you need you can use either Electrodroid or this little Windows program from a guy from Finland.
Old URL:
http://koti.mbnet.fi/jahonen/Electronics/ResOptimizer/
Modified updated URL 21.11.2013:
http://koti.kapsi.fi/jahonen/Electronics/ResOptimizer/
Since I dont have an Android phone (yet) this is going to help me a lot ;)
Just wanted to share what I found. Please feel free to reply and share what similar stuff you found.
« Last Edit: November 21, 2013, 11:08:11 pm by Chipguy »
Where is that smoke coming from?
Offline BravoV
  • +++ ATH1
I believe that guy is one of the member here with nick ... Jahonen.  :P
Offline jahonen
Yes, that is done by me. Nice if you find it useful. I myself tend to use it all the time :)
Regards,
Janne
Offline Six_Shooter
Neat!
Yes, it is indeed very useful. I also like the configurability with the "ser" files very much.
For some reason something like this is a hard-to-find tool. If I wouldn't have found yours, I would have had to write one myself.
That would have taken hours or even days to do.
Thanks man !
Offline zx80nut
Oooh - looks very useful. I'll download it now.
...the number of times I've taken the trial-and-error approach to get a value this will be a really useful utility.
Thanks.
Grant
Online sleemanj
  • Professional tightwad.
My javascript based solver isn't quite so powerful as that but it does the job, I use it to calc "stacks" of parallel SMD resistors to achieve a value using only the resistors I have...
http://sparks.gogo.co.nz/resistor_paralleler.html
Wolfram Alpha is also pretty handy, for example: http://www.wolframalpha.com/input/?i=72+Ohm
Offline kripton2035
I did the same (for mac os) 10 years ago ...
Thanks for all your replies.
There are some useful tools out there which all have their highlights.
I think I like Jahonen's tool the most.
The one for the Mac looks interesting too.
Offline LukeW
There's a great little website tool I like to use here:
http://jansson.us/resistors.html
Not only does it choose series or parallel combinations of a couple of resistors, using standard E-series values, to try and meet a specified target resistance, it also does resistor ratio calculation choosing from standard E-series values, which is handy when designing opamp or voltage-regulator feedback circuits.
Personally I think a website applet is more appealing than having to download and install some binary on your PC... especially if it's Windows-only.
I found another use for the tool today:
Since there is a list of E-Series resistors to select from it also serves as just an E series standard value table.
Before that I used to have a look into a Wikipedia aricle every time.
Cheers
Chipguy
Offline codeboy2k
I put all the links to the resistance calculators that were mentioned in this thread into the EEVBlog wiki  here : Resistance Calculators (wiki)
The Wiki doesn't get enough love :)
