Author Topic: 5 t0 12 volts problem  (Read 2513 times)
Offline J4e8a16nTopic starter
    • Jean Pierre Daviau
« on: February 12, 2014, 02:39:56 pm »
I did another circuit where the the output voltage was coming out of a 555 timer #3 pin to a transistor with a relay (12 volts) working on  12 volts. It was fine.
On this one how could I maintain the base voltage to 1 volt or so? When I clap with the pin 6  to the 5 volts ground. I get 3.75 volts and 30 mA.
The relay is a 12 volts.
« Last Edit: February 12, 2014, 02:41:58 pm by J4e8a16n »
Equipment Fluke, PSup..5-30V 3.4A, Owon SDS7102, Victor SGenerator,
Isn't this suppose to be a technical and exact science?
Offline Paul Price
Re: 5 t0 12 volts problem
« Reply #1 on: February 12, 2014, 07:24:47 pm »
The base voltage cannot be set higher than approx .7V with your circuit> The ON base-emitter voltage of a silicon BJT sets this limit,
But why try? With your circuit as shown it would work fine with just the resistor in series with the base.
« Reply #2 on: February 12, 2014, 07:44:50 pm »
I assume you take note that the bjt is at 12volts and the TTL at 5 volts...
Well why does not this work ...?
Thank you for your interest.
JP
« Reply #3 on: February 12, 2014, 08:34:29 pm »
It does  work  ;D
This app  square the input from the electret then add multiple waves in one long wave . It authaurize only one 'clap'.
I am using an old electret (probably 45dB) with this application and it is not very efficient.
It gives 3 volts at pin 7 .
I have seen a $5 dollars electret  producing 60 decibels.  My problem is I have to clap at least at 2 feet for the application to work.
Have any opinion on this?
« Last Edit: February 13, 2014, 11:40:46 am by J4e8a16n »
