Author Topic: 5 Volt UPS Hack  (Read 1438 times)
Offline David HessTopic starter
  • DavidH
5 Volt UPS Hack
« on: April 06, 2025, 10:23:01 pm »
The other night I finally get fed up with power outages killing my internet.  The only part of my network without backup power is one MOCA adapter (Ethernet over 75 ohm coaxial cable) that is in an inconvenient location.
I have an old but serviceable 12 volt UPS originally intended for a modem, however the MOCA adapter is 5 volts and the 12 volt UPS needs a replacement battery.  I did a search for 5 volt UPS units but did not fancy any of the options that I found.  I want something which has a user replaceable standard battery and wide input voltage range.
So in the meantime I soldered 4 x 10 year old alkaline D cells in series and added enough diodes to control the voltage thresholds with the original 5 volt adapter.  D cells should provide about 2 days of run time.  Eventually I will likely add a 5 volt regulator to my existing 12 volt UPS.
« Last Edit: April 06, 2025, 10:25:31 pm by David Hess »
The following users thanked this post: pardo-bsso
Offline bdunham7
Re: 5 Volt UPS Hack
« Reply #1 on: April 06, 2025, 10:30:16 pm »
Your scavenging and repurposing skills will be valuable in the coming post-tariff apocalypse.
The following users thanked this post: BILLPOD
  • DavidH
Re: 5 Volt UPS Hack
« Reply #2 on: April 06, 2025, 10:31:10 pm »
The batteries are 10 years old.  The diodes are at least 30 years old.
If I extended the coaxial cable, then I could place the MOCA near my existing UPS.
« Last Edit: April 06, 2025, 11:04:10 pm by David Hess »
