Author Topic: 555 timer project?  (Read 2769 times)
Offline greencardiganTopic starter
555 timer project?
« on: November 06, 2011, 06:10:02 am »
Hi
I have a little project I'm working on and I'm thinking a 555 timer or 2 might be able to help.
I have a switch connected to a clock that is open for 5 minutes then closed for the remainder of the hour. As the switch closes I want to generate a 1/2 second high pulse.
Is this something I can use a 555 for?  I've had a bit of a play and couldn't work it out. In monostable mode the trigger has to be shorter than the output pulse.
Any ideas??
Offline IanB
Re: 555 timer project?
« Reply #1 on: November 06, 2011, 07:11:31 am »
You can use a capacitor and a resistor to generate a short trigger pulse from the switch closing event. You use the property of a capacitor that the voltage on one side will try to follow a changing voltage on the other side. So you connect the switch on the upstream side of the capacitor and the 555 input trigger downstream. Then you ground the downstream side of the capacitor with a suitable value resistor so it is normally pulled low.
When the switch closes it will momentarily raise the capacitor voltage and trigger the timer. However, the resistor will then discharge the capacitor back to ground taking the trigger signal away again.
Offline IanB
« Reply #2 on: November 06, 2011, 07:41:08 am »
I guess you need a resistor to ground on the upstream side of the capacitor as well to reset it after the switch opens.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #3 on: November 06, 2011, 11:27:11 am »
you could possibly do this also with a comparator
