As stated above, the 74LS14 and 7414 have normal TTL current-sinking outputs, which are only guaranteed to go to Voh > +2.4 V. The suggested pull-up resistor (to +5V) is probably needed to drive a CMOS input. If you don't want to unsolder the device, try tacking in a leaded resistor and see if that resolves the problem. You can calculate the resistor to source the maximum recommended Iol (at low output) from +5V. The CMOS versions of this part are a better choice, if you can remove the original part.
Besides the voltage level problem when connecting 7400 outputs to CMOS inputs, the TTL pull-up output sources less current than the pull-down can sink, and may have problems driving capacitive loads in the positive direction.
