Old topic, new finding.
I would also like to add that Hakko T12 soldering stations (FX-950/FX-951/FX-203) use 270 degree DIN 8-pin versions. The Aliexpress handle Hakko clones for T12 tips, like FX-9501 handle with 8-pin connector, are NOT compatible, even though look similar. The problem is the center pin which on clones is located in between 9:00 and 3:00 pins. You can clearly see that on proper
DIN connector 8-pin version a center pin is not at the very center of the shield.
The solution is to either buy a proper 7-pin DIN connector or to cut out the center pin (for these handles a center pin is NC). Otherwise the connector is going to be misaligned and won't mate reliably.
