Ok, this is my scenario, I have an 80A 5V DC supply which I am only using around 55 Amps. I went and purchased new 8 Gauge low resistance power cable from my local electronics shop. I am using high quality spade lugs to bolt to +/- output which are connected to the 8 gauge cable and then to my test load which is a 250W Dale .1 Ohm 1% resistor. I have got only .00137 Ohms of resistance in the cables, checked with my 4-wire Kelvin on my Agilent DMM. The power dissipation is mostly through the Dale load resistor, but I am getting quite a bit of heat in the cables still. By my calculations, I should have around 4.932V across the load, and it is about 5V across the load. The rest dropped over the cable. Now, I realize that their is still a fair bit of current flowing through the wire, but my power dissipation over the 6 feet of cable at .00137 Ohms should be relatively low. I think, but am not certain the heat is conducting back through my load which is damn hot because the temperature of the cables seem to be hotter towards the load. So, one would speculate that the heat from the load is traveling back up the cable but it's pretty warm even at the supply side of the cable.
I only ran the test for about 10 minutes, that's all my load could handle because it was running at full potential.
My question, Could some of this heat be radiating back up the cable that far?
