Author Topic: A cheap RTC with integrated crystal  (Read 6474 times)
Offline ali_asadzadehTopic starter
« on: December 07, 2015, 08:53:37 am »
Hi
There are many solutions out there,But I need something with these capabilities
A RTC chip with integrated crystal in it and should  have a serial interface like I2C or SPI,have a small package and should be under 0.6USD at 1K QTY. also having internal RAM would be nice too
I fall in love with M41T62 from ST,the only problem is it's price. Do we have cheaper alternatives? where is china in this market?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline lm3baker
Re: A cheap RTC with integrated crystal
« Reply #1 on: December 07, 2015, 11:57:24 am »
I don't know of cheap ones with a built-in crystal (this seems to come with a price premium), but most of the ones with crystals are $1.50+
I did spot the NXP PCF2129 at 1.42/ 2000qty from digikey, and also found DS3231 from maxim, but being maxim it costs an arm and a leg ($5 per 1000 or so). [ edit: Maxim has quite a few see https://para.maximintegrated.com/en/results.mvp?fam=rtc ] Microchip and Rohm don't appear to have the built-in osc type RTC.
As for the Chinese options, a quick search gives me the JYRTC-1 http://www.jingyuan.com/UploadDrivers/201371155141119.pdf, website http://www.jingyuan.com/Showpro.asp?id=68&biaoming=product5, info in English http://tongfangguoxin.manufacturer.globalsources.com/si/6008849732923/pdtl/Crystal-oscillator/1132629984/Real-Time-Clock-Module.htm but I don't have a price on that.
I have used in the past some very cheap, low power (<<500nA) devices from NXP in the past (runs for months off the 3.3V 1F cap 8) ), but they need crystals.
As an aside, it looks like RTCCs have improved a little bit over the last few years (lower currents, SRAM/NVRAM persistent storages).
« Last Edit: December 07, 2015, 12:12:46 pm by lm3baker »
Offline Pjotr
« Reply #2 on: December 07, 2015, 01:04:32 pm »
All depends on accuracy. The integrated ones have a premium here, but at a price. If accuracy is not a major issue, a separate crystal stays cheapest. Epson has also some integrated ones.
Offline Fungus
« Reply #3 on: December 07, 2015, 01:43:49 pm »
Yep, embedding a crystal into a chip is expensive.
Why does it have to be internal though? Crystals are cheap/small.
Offline rdl
« Reply #4 on: December 08, 2015, 03:25:25 am »
The ones with internal crystals can be temperature compensated and factory adjusted for accuracy. Using an external crystal it takes a bit of effort to get better than +/- a couple of minutes a month. Something like a DS3231 is specified for +/- a couple of ppm as supplied, which is just a few seconds per month.
edit: removed extra word
« Last Edit: December 08, 2015, 06:23:24 am by rdl »
« Reply #5 on: December 08, 2015, 06:20:20 am »
Thanks for your help. embedded crystals bring accuracy, The question is why these chips are priced higher than a MCU with lots of capabilities including a RTC!, Maybe chines friends have something cool for us.
