Hi all!
Now that I have a decent high vacuum system, I'd like to put it to use.
I want to build a simple ion gun, able to operate from my 0-3 kV 10 mA PMT PSU.
See attached schematic.
The vacuum feedthroughs are all ready.
My plan is to soft solder everything, cups and tubes soldered from 20 um copper foil, elements supported by heavy enameled copper wire.
The basic test is to see if I can get any current to shop up on my electrometer (will be a vacuum tube ion chamber sans chamber).
Later, with a viewport maybe drawing a dot on a piece of CRT screen.
I am a complete noob at ion optics, however, so I'd like the opinion of you all before I power it up.
Since the filament supply will be at high voltage (very inconvenient - can polarity be swapped?), I will make a plastic enclosure right at the feedthrough to house it, and operate the potentiometers by 10 cm glass rod/tube elongations.
Have I missed anything?
Thanks in advance!
