I am close to finishing a long-running project: a preamplifier (including RIAA equalization) using 7586 Nuvistor triode vacuum tubes. I tested prototypes for the stages using laboratory power supplies with good results. Unfortunately, I had naively looked at power-supply rejection only at 120 Hz (easily obtained with filter capacitors on the DC lines). Since the individual stages (CC, CC, CF per stage) are DC coupled, the rejection at frequencies below audio is not good enough for an unregulated power supply. Looking into that problem, I found that the DC fluctuations are caused by short-term fluctuations in the AC line voltage.
Specifically, I measured the nominal 120 V 60 Hz line, measured with an Agilent U1252B 50,000-count DMM at 7/sec display rate, in TRMS AC voltage mode. Logging max, min, mean over 240 sec measurement time, I found 1.47 V pk-pk, or 1.2% of 121.6 V mean value fluctuations. This corresponded roughly to the fluctuations of the DC line, monitored on an analog CRO, where the characteristic time of the fluctuations was roughly 0.5 sec. I moved the voltmeter from the workbench to an outlet immediately adjacent to the breaker box (with no other loads) and saw 1.1% pk-pk fluctuations on a slightly higher average value. These measurements were done on a cool day with the central air conditioning off.
My question is: is this level of short-term fluctuations normal for the residential AC line in an American city?
