Hi
I ask before but I dont get any usefull replays to.
I hope that is the right area to ask.
I got this Camera Module a long Time ago:
https://www.delock.de/produkt/96371/pdf.html?sprache=enThe sayed it have, use a "• Standard SCCB interface (I²C Bus)" not how to access that?!
I need to change the resolution to QSXGA (2592 x 1944) for the best Images possible.
Disable the " - Automatic white balance (AWB)" and so on.
The Manual also say the use a Serial Interface but now how to access that?!
I download the Manual from OV. The are very good!
At first i would like active the Test Pattern to see I can change settings:
0x503D PRE ISP TEST
SETTING 1 0x00 RW
Bit[7]: Color bar enable
0: Test disable
1: Color bar enable
Bit[3:2]: Color bar style
00: Standard eight color bar
01: Gradual change at vertical
mode 1
10: Gradual change at horizontal
11: Gradual change at vertical
mode 2
But how the get the Code into the damn Module?!
Thanks!
