Single phase? Do you want to look at one side? Do you want average or peak? The output centers around 2.5V. A three terminal LM431 trips at 2.5V. Add a pot and you could easily look at one side of the waveform and look at the peak. A PNP transistor could then invert the signal. Or use a comparator, the 431 could be your reference.
