Author Topic: Active Load  (Read 3729 times)
Offline janengelbrechtTopic starter
    • JP-Electronics
Active Load
« on: November 13, 2014, 07:00:05 am »
Inspired by Daves Active Load design:
Suggestions and comments will be appreciated  :D
Its seems to work...but i need another FET and rail-to-rail OpAmp.
The expensive 10 turns pots is not ideal too.
My problem really is that i think the opamp that drive the MOSFET ought to have an output voltage at 4.5V...but it is nearly 1 Volt higher....hmm..... maybe I ought to go back to my uni and start all over :P Not that it in any way influences the function of the circuit :P Its just....it shouldnt really work as i see it :P ....but it does :P
(The OpAmp U1:A has a resistor with a really high value : Gate-source resistance in MOSFET as its feedback resistance so it ought to have an amplification near its Open Loop Av. So one would assume it acts like a comparator ? Then it should settle at half supply when there is 0 volt difference between its inputs. Well if such things as offset errors didnt exist - Tried to remove R2 - no difference! :P What is it i am missing ? God damn...now i can feel i only has worked with software the last 19 years :P ??? )
« Last Edit: November 13, 2014, 07:44:05 am by janengelbrecht »
Offline Richard Head
Re: Active Load
« Reply #1 on: November 13, 2014, 07:54:51 am »
Why two pots and not just a resistor in series to limit the range?
I would add a bit of hysteresis on the current limit so the current limit LED either goes ON or OFF and not gradually switches on.
I suggest some bypass caps across the power rails and Zener also.
    • JP-Electronics
Re: Active Load
« Reply #2 on: November 13, 2014, 07:57:39 am »
Hmm two pots for coarse and fine adjust :)
Your other advice i will implement at once - thx....still i have some troubles understanding why it actually works :P
In my next project i will not use this trial/error approach in my design proces but actually calculate it all first :P
Current limiting LED: It really doesnt gradually turn on/off..... :) Its either ON or OFF :)
« Last Edit: November 13, 2014, 08:02:03 am by janengelbrecht »
Offline Seekonk
Re: Active Load
« Reply #3 on: November 13, 2014, 08:48:52 am »
I would expect to find the fine pot to be in series with the course pot source voltage source OR something like a 20K resistor in the lower leg of the fine pot.  As it is the course pot sets the max voltage and the fine pot is 0-100% of that.
