Author Topic: Active Pickguard  (Read 4468 times)
Offline ehughesTopic starter
Active Pickguard
« on: October 30, 2011, 02:58:50 am »
Now that the contest is over (I didn't win....)   I can show off the guitar:
Done with Altium Designer,  Freescale Code Warrior,  Alibre Design and Front Panel Express.
Offline DrGeoff
    • AXT Systems
Re: Active Pickguard
« Reply #1 on: October 30, 2011, 07:06:49 am »
What a great project. Really nice design and a good presentation.
Not sure I'd keep the RJ connection though, could be damaged over time with consistent use (or roadies stepping on them). Had you considered those mini multi-pin XLR connectors?
Was it really supposed to do that?
Offline sonicj
  • updata successed!
« Reply #2 on: November 01, 2011, 12:41:14 am »
wow! that is exceptional work!
i found the part about the piezos very interesting. how do they behave with extreme temperature changes? ie: going from a 70°F car to a 93°F outdoor gig?
the additional sensors & inputs adds a lot of potential for creativity and possibly even integration with other devices. ie: stage lighting triggering, IEMs, midi, etc.
i like the cheap & readily available concept of the CAT6 cable, but like drgeoff, i question its ruggedness in a get drunk and get stepped type on environment. neutrik has their ethercon connector that looks roadworthy.
again, my hats off to you! great job!
-sj
« Reply #3 on: November 02, 2011, 12:56:33 am »
I'll take a look at the ethercon.  The Cat6 has been somewhat of a novelty item.   The shielded Jacks and cables through can take quite a beating though.  I was a bit surprised as I have seriously abused them here.   When I play out I wrap the cable from behind the strap for strain relief.   Standard 1/4" Jacks are absolutely horrible for this..... You have to do the strain relief trick.
I have looked at the Mini XLR and they look cool.  Right now I use 3 pairs --> Power/GND, AES3+/AES3-, Analog+/Analog- .   The analog is balanced line as well as the digital out.   I really wish all musical gear would let 1/4" unbalanced die off.....  Balanced line is so much better.
My dream is to have the Ethernet jack right on the amp.  Nothing Else.   All  control is on the Pickguard.   I like the minimalist approach to the amp. (A dumb gain stage!)
That being said,  wireless would probably be V3.....   Need to figure out a battery and good low latency (i.e. one sample period) wireless technology.
I plan on open source everything at some point (if there is interest).   The debugger/JTAG interface is built onto the pickguard.   Codewarrior is free for 128k and works with both linux and Windows.  I am sure there is someone out there who has an unencumbered ARM cortex M4 GCC toolchain ready to go....   The hardware isn't cheap though....
« Reply #4 on: November 02, 2011, 12:59:28 am »
I think you sold me on the ethercon .  They sell the housing without the cable and even have nice PCB mount connectors!
Offline shadewind
Active Pickguard
« Reply #5 on: November 04, 2011, 10:03:43 am »
I'm an old school kind of guy so I'd probably never use this myself but I think this is a really amazing and brilliant project. Very innovative! Excellent work!
