Author Topic: AD9850 DDS module  (Read 4468 times)
Offline akisTopic starter
AD9850 DDS module
« on: November 30, 2014, 09:00:43 pm »
I have got a bunch of these modules on ebay from different suppliers. I have noticed that a few do not work properly, from the ones I have tested. What happens is sometimes they produce a nice sine wave output at the desired frequency, and sometimes they do not. Flicking the Vcc line sometimes fixes the problem (if you can call that a fix). To explain further, when I flick the Vcc line, the AD9850 module does not power down completely as it is being kept half-powered by the 4 wires connecting it to the Arduino board. But it seems doing this "nudges" something and then the AD9850 starts, even though the Arduino was doing nothing at the time, which further means that the frequency was already transmitted properly but the AD9850 was refusing to produce it, until I flicked the Vcc line.
If anyone has any ideas please let me know.
Many thanks.
Offline c4757p
  • adieu
Re: AD9850 DDS module
« Reply #1 on: November 30, 2014, 09:14:20 pm »
Are you twiddling the reset line on startup?
« Reply #2 on: November 30, 2014, 09:48:58 pm »
Only when I program it as part of the programming code. But when I flick the Vcc line, the programming has already been done.
Anyway out of 6 modules, 4 work OK, and 2 are funny like that. For my luck, picking randomly out of the box I soldered the one that is funny... I have replaced it now with one that works.
My small worry is that maybe I am doing something wrong and the ones that work only do so out of fluke.
Offline dannyf
« Reply #3 on: November 30, 2014, 09:51:11 pm »
I have used maybe 10 of such modules. No problem whatsoever.
Maybe. or even likely.
Offline Rigby
  • Learning, very new at this. Righteous Asshole, too
« Reply #4 on: December 01, 2014, 12:33:49 am »
Seems more likely to me that he's doing things right, or right enough, but that there are some counterfeit or maybe "overused" parts that found their way to him.
Check the data sheet and make sure you're within tolerances everywhere.  If you are, then you have bad parts.  Bad meaning counterfeit, used and broken, or parts rejected in QA.
« Last Edit: December 01, 2014, 12:58:22 am by Rigby »
Offline Rasz
    • My random blog.
« Reply #5 on: December 01, 2014, 12:45:47 am »
start by measuring voltage
when it works, when it doesnt, and when you do your secret flick
