If you need it so precisely, you should probably just do it with a DSP. Switched capacitor might be okay (if you don't mind that it's Maxim), but mind the other aspects of them as well (reduced high frequency bandwidth, switching noise).
If you don't need exact steps, but rather a tolerance range is acceptable, then a number of methods might be applicable. See also OTA filter circuits.
