Author Topic: Adjustable CC/CV PSU using laptop AC adapter?  (Read 7678 times)
Offline nbrittonTopic starter
« on: October 03, 2015, 03:53:05 am »
I have a 230W +19.5VDC laptop AC adapter that I'd like to adapt into a triple output variable constant current / constant voltage power supply. I'm sure something like this has already been done, any pointers where I can find more information about this? How would you accomplish this without using grossly inefficient linear regulators?
Offline ez24
  • L.D.A.
Re: Adjustable CC/CV PSU using laptop AC adapter?
« Reply #1 on: October 03, 2015, 05:30:07 am »
230W +19.5VDC laptop AC adapter  ==>  what brand ?
I'm sure something like this has already been done  ==> good luck
Online Kleinstein
« Reply #2 on: October 03, 2015, 07:50:54 am »
If you don't want a pure linear regulator, it will be a switched mode regulator. Except for the input voltage there will be no big difference to starting from rectified mains voltage, except that one channel might use a step down without isolation.
Offline Fungus
« Reply #3 on: October 03, 2015, 11:41:15 am »
Browse eBay, there's dozens of things like this: http://www.ebay.com/itm/351276332291
Offline rjeberhardt
« Reply #4 on: October 03, 2015, 02:12:21 pm »
I've done exactly that using one of these: http://www.ebay.co.uk/itm/5A-0-8V-29V-Constant-Current-Voltage-LED-Driver-Step-Down-Module-Charger-Module-/131584272548?hash=item1ea308a8a4 and an old Dell 20 V 3.5 A laptop power supply.  It works O.K. but when tested at 1.5 A load it gave 50 mV triangular wave ripple at about 300 kHz with 100 mV switching spikes with a fundamental frequency of about 10 MHz.  So, if you want to use it to power anything sensitive you need to be careful with the filtering.
Russell.
Retired Chartered Engineer
Offline ez24
  • L.D.A.
« Reply #5 on: October 03, 2015, 07:09:41 pm »
Russell.
Did you have to do anything with the center pin to get it to work?  (Dell PS use 3 wires)
Offline ez24
  • L.D.A.
« Reply #6 on: October 03, 2015, 07:59:29 pm »
There is no 3 output buck off the shelf item.
Here is a +- 12v buck  (rare item), using this and one of the ones you have picked, would give you a triple output
http://www.ebay.com/itm/251352773668?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
There are a lot of dual bucks that put out 12v and 5v
Offline Fungus
« Reply #7 on: October 03, 2015, 08:03:23 pm »
No, but you have have 3 single output bucks.
Offline rjeberhardt
« Reply #8 on: October 04, 2015, 09:02:48 am »
No.  The one I had just had a two wire output.
Russell.
Offline jay
  • Country: ee
  • Coder
« Reply #9 on: October 05, 2015, 03:05:03 pm »
So did the ripple come from the module you got from that Ebay seller or from the Dell laptop power brick?
I've used Lenovo & IBM laptop PSUs for many projects including a bench power supply. The ripple is surprisingly low even at high currents (IIRC, I tested up to 4A). There was a bit of voltage drop at high currents, but that probably comes from the long cable and replacing the cable with something thicker would probably fix that. There might be a clear quality difference between brands.. At least I had several old power bricks from other brands and many of them didn't work at all or had serious issues with regulation or ripple.. Well, many were 10 years old so the output caps had died. Good to check them carefully before using.
SW engineer trying to design HW because it's more fun.
Offline Fungus
« Reply #10 on: October 05, 2015, 03:25:01 pm »
I always thought the little center pin was some sort of voltage sense feedback to adjust for that. I might be wrong though, I'm just guessing.
Offline ajb
« Reply #11 on: October 05, 2015, 04:03:17 pm »
Dell at least uses the center pin to read an identifier from a little one-wire device in the adapter.  That way the laptop can identify whether a 65W or 90W adapter is connected and nag at you if you connect the wrong one.
Offline rjeberhardt
« Reply #12 on: October 05, 2015, 06:34:30 pm »
The Dell PSU gives very little ripple on no load but when loaded the ripple shoots up to about 100 mV PP.  However it is switching at 200 kHz.  The ripple I'm getting on the Ebay module output is 300 kHz so is coming from that module.
Thinking about it, a switching regulator feeds a pulse waveform into an LC tank circuit which converts the pulse waveform into a triangular waveform (the ripple).  The feedback is taken from the capacitor.  There must always be that triangular ripple on the output unless further filtering is added.  The Ebay module has the output connected directly to the tank circuit so external filtering is needed if low ripple is required.
Russell.
Offline ez24
  • L.D.A.
« Reply #13 on: October 05, 2015, 07:54:59 pm »
Just curious - on the output of the buck is there any 200 KHz from the Dell?  Also what is the PP of the ripple from the buck, you say it is 100 mV PP on the input to the buck?
Offline rjeberhardt
« Reply #14 on: October 06, 2015, 08:50:54 am »
O.K. here is the output of the buck converter on 10 V output with a 10 ohm load and with no additional filtering:
The triangular wave is 40 mV pp at 277 kHz.  (Ignore the frequency counter it is triggering on the switching spikes).  There is no sign of the ripple from the Dell PSU getting through.   The ripple changes very little with the load.
Russell
« Last Edit: October 06, 2015, 08:55:32 am by rjeberhardt »
Offline ez24
  • L.D.A.
« Reply #15 on: October 06, 2015, 08:57:58 pm »
Russell
thanks
Online Siwastaja
« Reply #16 on: October 07, 2015, 06:13:56 am »
Do the three outputs need to be isolated from each other, or can they share common ground?
