Is there an obvious way to implement foldback current limiting with contemporary linear regulators that I am missing? I haven't really seen a part like the uA723 which would give me the low level access to internal nodes that I seem to need for this purpose.
Foldback current limiting is implemented in integrated regulators because they have strict secondary breakdown and power limits, so it is required just for an integrated regulator to survive. The same applies to discrete regulators to a lesser extent, where inexpensive high power transistors with good safe operating area are available. Bench power supplies rarely implement foldback current limiting, although they might include thermal shutdown.
The example you show implements foldback current limiting as part of Vbe current limiting, which is not very precise, but should be easily good enough for a regulator as part of a larger assembly. For an LM317, foldback current limiting will require the current shunt to be placed on the input to avoid spoiling the LM317's load regulator. And of course foldback current limiting is much easier where you have access to internal nodes, like with the uA723.
I would not worry about the 723 going out of production. It is the basic element of a lot of mass produced linear power supplies. But the advantage of using the LM317 is that it has built in protection for its pass element, which the uA723 does not have.
Tektronix almost always implemented foldback current limiting for their discrete linear regulators inside their oscilloscopes around the 1970s, so there might be something to learn from their fully documented designs of that era. They used differential pairs for voltage and current limiting.
I do not see any published foldback current limiting circuits for the LM317, but it would not be difficult to design one from scratch.
