I just received my Spellman and it turns out the customized (PCM50P75X2287) model has a different control interface from the usual PCM modules
. It has a DB25 connector rather than the 15 pin connector on the manual, but on the PCB, it's internally connected to the 15 pin footprint.
The wiring for the DB25 connector is:
mA Prog: 13
kV Prog: 6
mA Mon.: 10
kV Mon.: 4
Enable: 2
Interlock Out: 9
+10V :23, 24, 25
GND: 1, 5
Fault: NC
Something unknown: 13, 14
Also the local programming potentiometers are not installed, the logic of enable is inverted (grounding to inhibit) and it doesn't seems to have slow start.
