I am trying to design a circuit with an adjustable Inverting Buck-Boost (IBB) using the LM43601. The IBB takes +5 V as input and can produce any voltage in-between -5 V and -24 V. The output voltage should be adjustable through a sink/source current DAC, namely the DS4432. Now the question arises if this is possible, and if so, how should the level shifting look like for the signal between DAC and the FB pin of the IBB?
For reference, I have attached the schematic of the IBB. The FB_NEG label shows where the current shall get injected from the DAC.
