Author Topic: Advice needed  (Read 8761 times)
Offline BaliszoftTopic starter
  • Country: hu
Advice needed
« on: November 20, 2012, 01:06:04 pm »
I got this small board, which consists of a 128x64 GLCD module, a beeper, and two connectors (RJ45 female and USB Type-B female). On the bottom, there is a pic. It is a custom job, it has nothing to do with pc networking i was just using the RJ45 because of the easily available networking cables. Now i want to make this board smaller in height (i am going to use a COG display). I could use a mini USB connector, but i could not find a replacement for the RJ45. Can you suggest me a 8 pole connector which is preferably not wider than the RJ45, but still lower? Pin headers are no go, as this is going to be a commercial product.
Offline peter.mitchell
Re: Advice needed
« Reply #1 on: November 20, 2012, 02:51:27 pm »
Could you just mount the socket on the reverse of the board?
  • Country: hu
Re: Advice needed
« Reply #2 on: November 20, 2012, 03:01:07 pm »
Uhm well, yes. I want to make the board and its enclosure as thin as possible.
Offline Psi
Re: Advice needed
« Reply #3 on: November 20, 2012, 03:05:49 pm »
There's a round connector that looks exactly the same as a S-Video connector but with more pins.
just googled, its called a 9 pin mini-DIN
http://www.allpinouts.org/index.php/9_pin_mini-DIN_%28VIVO%29
Its often used on videocards for the VIVO cable (video in and video out) and carries multiple input/output channels
  S-video, composite, component etc..
It might be a little lower than an rj45
« Last Edit: November 20, 2012, 11:57:35 pm by Psi »
  • Country: hu
Re: Advice needed
« Reply #4 on: November 20, 2012, 03:39:10 pm »
Hmm. Not a bad idea. Thanks! I will check how it could work out. The rj45 stlyle plug has a big advantage though: it has a lock and that comes quite handy.
  • Country: hu
Re: Advice needed
« Reply #5 on: November 20, 2012, 03:44:04 pm »
Checked this: http://www.farnell.com/datasheets/28805.pdf
Sadly it has got the same height as the rj45 :/.
Offline Circuitous
    • Corgi-Tronics
Re: Advice needed
« Reply #6 on: November 20, 2012, 06:28:40 pm »
Do you really need all 8 of the ethernet wires?  If you aren't using POE, then you should only need 4 connections.
The only complication in replacing the RJ-45 is if it has built-in magnetics.
Online kripton2035
Re: Advice needed
« Reply #7 on: November 20, 2012, 06:56:24 pm »
Offline WBB
Re: Advice needed
« Reply #8 on: November 20, 2012, 07:06:49 pm »
Mini HDMI? It's small and has plenty of pins.
  • Country: hu
Re: Advice needed
« Reply #9 on: November 20, 2012, 08:03:03 pm »
Yes, i need all the 8 wires. It is not used for ethernet.
  • Country: hu
Re: Advice needed
« Reply #10 on: November 20, 2012, 08:07:17 pm »
some connector like this one is locked
http://www.ebay.com/itm/5pcs-Aviation-Plug-Male-Female-Wire-Panel-Connector-16mm-8-Pin-GX16-8-/400340089966
These are really cool. Too bad, that they got the same height as the rj45. :(
I would need something around 6-7mm max.
I already thought about HDMI, but they are a bit fragile imho.
Offline daedalus
Re: Advice needed
« Reply #11 on: November 20, 2012, 08:41:45 pm »
any reason you cant just use a molex or jst connector? both do locking connectors in a variety of form factors, and are relatively cheap. I tend to use picoblade/picoclasp in a lot of the boards I design, picoblade is only 3.5mm height.
if this is a product then you should avoid abusing commonly seen sockets. Users expect an rj45 to be Ethernet, and a hdmi to be video, if you use them for something different you better be damn sure that neither your device or their tv/computer are damaged when the stupider ones hook them up. Some footnote in the manual wont really cut it, as most wont ever read it.
  • Country: hu
Re: Advice needed
« Reply #12 on: November 20, 2012, 09:06:03 pm »
Yes, you are right in every aspect. I am however keen to use mini-DIN type connectors, with a longer wire soldered on the board and a receptacle. To make the life harder, this wire has to go thgough a grommet on a cars firewall :)
Online kripton2035
Offline hlavac
  • Country: cz
Re: Advice needed
« Reply #14 on: November 21, 2012, 10:54:43 am »
How about these - plug, socket? Looks like RJ45, but flatter, with clips on the sides.
Good enough is the enemy of the best.
  • Country: hu
Re: Advice needed
« Reply #15 on: November 21, 2012, 11:30:16 am »
Excellent find, thanks! I could seriously consider this, if it wasn't this expensive :( and the receptacle is still too high :(.
  • Country: hu
Re: Advice needed
« Reply #16 on: November 21, 2012, 11:32:05 am »
Looking at these, too.
