Author Topic: Algorithm for calculating LFSR counters  (Read 941 times)
Offline Forty-BotTopic starter
« on: March 14, 2023, 05:45:43 am »
Inspired by this post, I've coded up a version of that algorithm in python. It's quite satisfying in its simplicity
# SPDX-License-Identifier: Apache-2.0
import functools
import sys
def logbits(x):
    b = 0
    while x:
        if x & 1:
            yield b
        b += 1
        x >>= 1
@functools.cache
def logstep_bit(taps, bit, logsteps):
    if not logsteps:
        return (bit < taps[0]) << (bit + 1) | (bit in taps)
    return logstep_state(taps, logstep_bit(taps, bit, logsteps - 1), logsteps - 1)
def logstep_state(taps, state, logsteps):
    lfsr = 0
    for bit in logbits(state):
        lfsr ^= logstep_bit(taps, bit, logsteps)
    return lfsr
def step_state(taps, state, steps):
    for logsteps in logbits(steps):
        state = logstep_state(taps, state, logsteps)
    return state
if __name__ == '__main__':
    if len(sys.argv) < 2:
        print(f"""Usage: {sys.argv[0]} TAPS CYCLES...
Calculate the starting state to use with the LFSR defined by TAPS (as an
integer) which will go through CYCLES states before finishing.""", file=sys.stderr)
        sys.exit(1)
    taps = tuple(reversed(tuple(logbits(int(sys.argv[1], base=0)))))
    max_cycles = (1 << taps[0] + 1) - 1
    for cycles in sys.argv[2:]:
        cycles = int(cycles, base=0)
        if cycles > max_cycles:
            print(f"Maximum cycles is {max_cycles:#x}, got {cycles:#x}",
                  file=sys.stderr)
        elif cycles <= 0:
            print(f"Minimum cycles is 1, got {cycles}", file=sys.stderr)
        else:
            state = step_state(taps, max_cycles, max_cycles - cycles + 1)
            print(f"{taps[0] + 1}'h{state:0{(taps[0] + 4) // 4}x}")
Example usage:
$ time scripts/lfsr.py 0xD800000000000000 1 0xdeadbeef
64'hffffffffffffffff
64'h56ca713cb5be9f24
real 0m0.057s
user 0m0.057s
sys 0m0.000s
There's an alternative implementation of this program which stores bits by value (0x10) instead of position (7). It's probably easier to do things that way in C or verilog, but this was more elegant in python.
