An HP5334B can usually be had for cheap. If it doesn't already have one, you can install an ovenized oscillator. They're 100 MHz, so if you need more you probably need a different model, probably not a reciprocal. At one time Optoelectronics and Startek made tons of inexpensive counters for hams, but those days are gone. Now Opto only has a couple fairly expensive ones and I think Startek is gone entirely. Should still be many on eBay.
Then, of course, you need a GPS oscillator like Leo Bodnar to calibrate it!
