Author Topic: Altium behaving strangely.  (Read 3787 times)
Offline kvrestoTopic starter
« on: February 22, 2015, 01:21:01 am »
Hi Everyone.
I’ve been working on a PCB project with Altium and I’ve just come across a strange problem. For the first time in this project, when I make a change to my schematic, and compile and update my PCB, all of my components seem to re-import themselves into the PCB workspace as if this is a brand new design and never routed. Does anyone know what has gone wrong?
KV
Offline free_electron
    • SiliconValleyGarage
Re: Altium behaving strangely.
« Reply #1 on: February 22, 2015, 02:40:07 am »
Did you do a full reannotate while you had broken links ?
Try this
Go to pcb. Project -> componentinks
Hit the button to move all to the left column
Then click the button to link by designator.
That should restore the links
« Reply #2 on: February 22, 2015, 06:29:02 am »
I did that, and I have gotten the same results, all of my components have bee re-imported complete with rooms, all nicely sitting in their room ready to be placed and routed,...how frustrating, anything else I can do?
kv
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: February 22, 2015, 07:34:42 am »
Delete them all and re-import?  Then re-re-import to see if it worked?
What's the ECO saying it's updating?
Seven Transistor Labs, LLC
« Reply #4 on: February 22, 2015, 11:49:06 am »
That is very strange.
You  must have done some operation to let altium believe the components are gone.
Did you explode any compinents to primitives  while they were all selected ?
Did you do a group edit on designators so they are all blank ?
Anyway, altium keeps copies of your work. Go to the project history manager and roll back one or two versions and see if the problem goes away.
« Reply #5 on: February 22, 2015, 10:01:57 pm »
Well, I haven't got a clue on what I did to cause the problem, I was routing for ages, I had to swap two wires around on a chip, and when I recompiled and updated it all went very bad. Who knows what steps I performed in between.
Finally I recreated a new project, included my schematic and PCB file, and order was restored to the Universe. I just hope the problem doesn't came back.
Thanks for your help.
kv
Offline SArepairman
  • wannabee bit hunter
« Reply #6 on: February 22, 2015, 10:07:21 pm »
I had this happen and I don't renumber how I fixed it (though free electron did help). It fixed it for like 90% of my parts, some fuse would keep resetting itself but I just waited for the final spin to position it... easier to pretend its not happening so long its not like  15 parts doing it.
« Reply #7 on: February 22, 2015, 10:11:53 pm »
In my situation all parts were moved off the PCB area.
I should also say that the PCB and schematic files were first created in Protel 98, so I think this must be the cause of my problem.
kv
Offline Gandalf_Sr
« Reply #8 on: May 06, 2015, 11:38:21 am »
Reading this makes me glad that I now use Diptrace
If at first you don't succeed, get a bigger hammer
