Author Topic: AM modulation with Agilent DSO-X-2000  (Read 2445 times)
Offline tiofilo75Topic starter
« on: October 18, 2013, 06:40:20 am »
I've been playing with the build in wave generator on the oscilloscope and learning about AM modulation. I learned how to use the FFT math function as well which was neat since I could see the message and carrier frequencies instead of just drawing them out in class. The carrier frequency is set at 5 Mhz while the message frequency is set at 10khz.  I set the center frequency on the FFT to 5Mhz with a span of 50 KHz. These oscilloscopes are freaking awesome.
