Author Topic: Amp meter / shunt  (Read 2797 times)
Offline LiteaceTopic starter
Amp meter / shunt
« on: November 26, 2018, 05:35:36 pm »
Hello ALL. need a bit of advise, Ive, on the way to me an old server P.S it has 3 or 4 30 amp outputs that can be all joined together to produce about 100ish amps, I would like to if at all poss use an amp meter with shunt but how would I wire this up ?
Thanks
Offline rstofer
Re: Amp meter / shunt
« Reply #1 on: November 26, 2018, 06:03:00 pm »
For industrial applications, we use what are called '50 mV shunts'.  For example, a 100A 50 mV shunt drops 50 mV when 100A flows.  This is measured on a meter.
https://www.amazon.com/Shunt-Portable-Out-0-50-0-100/dp/B01M0JJZI1
The following users thanked this post: 001, Liteace
Offline chuckb
« Reply #2 on: November 27, 2018, 03:35:29 pm »
I had worked with 50 mV shunts for 20 years until I came across this installation restriction.
There is guidance from shunt manufacturers that a shunt should not be run continuously above 66% current. We tested that guidance with a 400 amp 50mV shunt connected to 1" wide bus bars and passing full current. It reached well over 100 deg C and was discolored when were were finished. I'm sure the calibration of the manganin shunt was changed.
If you have a 100 amp load I would use a 150 amp 50mV shunt.
I found two links with this guidance -
https://www.bluesea.com/products/9230/Analog_Meter_Shunt_-_100A
https://www.rammeter.com/media/bulletins/RamMeterInc_ShuntDiscussion1.pdf  page 2
« Last Edit: December 08, 2018, 02:37:09 pm by chuckb »
The following users thanked this post: Liteace
Offline rstofer
« Reply #3 on: November 27, 2018, 06:13:16 pm »
As with most things in the electrical business, we need to derate.  Operating a shunt at 66% makes all the sense in the world.
« Reply #4 on: December 03, 2018, 11:29:42 pm »
This amp meter has not got to be 101% accurate, it will be glanced at every now and again to see what load is on the power supply, the power supply can deliver 130 amp and there's no way I'll be supping all of those, Ive also looked at these
 https://www.google.es/imgres?imgurl=https%3A%2F%2Fi.ebayimg.com%2F00%2Fs%2FMTIwMFgxMjAw%2Fz%2FgGMAAOSwAvJXB2jH%2F%24_35.JPG%3Fset_id%3D880000500F&imgrefurl=https%3A%2F%2Fwww.ebay.com%2Fbhp%2Fac-ammeter&docid=ydOSyWtX60LaDM&tbnid=ZPebVklv4fNWPM%3A&vet=10ahUKEwjiz7T454TfAhWYSxUIHa3fCDAQMwitASgwMDA..i&w=300&h=300&bih=882&biw=1280&q=amp%20clamp%20digital%20panel%20%20meter&ved=0ahUKEwjiz7T454TfAhWYSxUIHa3fCDAQMwitASgwMDA&iact=mrc&uact=8
something like that for DC voltage, what'd think ?
Thanks
Offline spec
  • MALE
« Reply #5 on: December 04, 2018, 12:52:48 am »
Hi Liteace
I would have thought a current clamp meter would be ideal for your application. No wiring or shunt resistors to worry about. You can get current clamp meters for both AC and DC.
(don't make the classic mistake: the clamp goes over just one wire, not two ;D)
« Last Edit: December 04, 2018, 12:55:53 am by spec »
Offline NiHaoMike
    • Facebook Page
« Reply #6 on: December 04, 2018, 01:05:22 am »
There is guidance from shunt manufacturers that a shunt should not be run continuously above 66% current. We tested that guidance with a 400 amp 50mV shunt connected to 1" wide bus bars. It reached well over 100 deg C and was discolored when were were finished. I'm sure the calibration of the manganin shunt wad changed.
Could it be possible to run the shunt at its rating by improving cooling, such as with a fan or by attaching heatsinks with an electrically insulating thermal epoxy?
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Offline 001
  • Country: aq
« Reply #7 on: December 04, 2018, 08:52:55 am »
What the reason of it? The sensor element is simple piece of manganin alloy. Pick one rated for large current. It is simply more fat wire  :-//
« Reply #8 on: December 05, 2018, 09:47:04 am »
I need your help please Guy's, I dont really want exposed shunt sitting on the top of the unit me or someone else, more likely me with at some stage put something on it and short it all out, Im thinking of getting one of these, then I can have everything rubbered and short proof but I would if poss need help on what gauge to use with it
http://www.chieful.com/pdf/Open/split/2--CS500EK1.pdf
Thanks
Offline 001
  • Country: aq
« Reply #9 on: December 05, 2018, 12:57:57 pm »
Do You REALLY need a shunt? You can use DC current clamp now
It is the best way, since 50mv*100A=5W of heat for a long time
« Reply #10 on: December 05, 2018, 06:42:37 pm »
No, I hope not that why I looked at the hall effect current sensor but would need someones help as to what panel meter to use it with so its reasonably accurate
something like:
https://flexscada.com/product/hall-effect-current-sensor-ac-75a-dc-100a/
Thanks
« Last Edit: December 05, 2018, 08:37:29 pm by Liteace »
