Author Topic: Amplifier for using piezo knock sensor as microphone  (Read 410 times)
Offline rvalenteTopic starter
  • Country: br
« on: April 16, 2021, 09:19:07 pm »
Hello mates,
I'd like to make a small amplifier to use a automotive knock sensor as microphone and trigger my timing light (to check correct timing of diesel engines)
What kind of amplifier should i use? Inverted single ended? Differential? Instrumentation? I've not found much literature about it..
Attached a bosch knock sensor datasheet.
greetings
