Its a great insulation material, you will get a nice thin dielectric slot.
Your part manufacturer can prevent intended coating, however, by leaving a sacrifice tab and removing it after anodizing (bad to tools as it is very, very hard) or coat it with a removable masking laquer. Removing a anodized sacrifice will be expensive. Be aware that aluminium is self-coating a bit on air so process it fast.
