Author Topic: Another Constant Current #102 Implementation  (Read 3458 times)
Offline zargnutTopic starter
« on: December 19, 2011, 02:44:52 am »
I figured this looked like an interesting newbie project. I took advantage of the schematics published by chrisw957. thanks. Would have bought a board, but could not get a hold of him. I couldn't get it to work initially as I was hooking the pot up as I normally do (in series, without grounding it). I was advised by my infinitely smarter brother that this would not work in this application as there was no current passing to the OP amp. Still not entirely clear on this concept, if anyone wants to educate a newbie.
I added a power option for a transformer vs battery and threw it into a pseudo box. As I didn't have a fan laying around I left the sides open for ventilation.
I would love some advice on construction, materials, "next time" kinda stuff.
Here is link to pictures:
https://picasaweb.google.com/zargnut/Electronics_constant_load?authuser=0&feat=directlink
thanks
dan
Offline eternal_noob
  • Country: no
Re: Another Constant Current #102 Implementation
« Reply #1 on: December 20, 2011, 01:33:35 am »
The reason why this doesn't work properly is because most of the op-amps have a high input resistance to ground. So if you think of the potmeter and the input of the amp like a voltage divider, the potmeter just becomes the uppermost part of the voltage divider. In this case you can only adjust the voltage by 50 millivolts or so. And, remember that there is always a relationship between voltage and current...
I have made a little demonstration for you. You need to have Java installed and a little bit of patience (the applet is a slow starter sometimes). The I Meg. resistor represents the op-amp input resistance in both instances.  Hope you'll understand things better now..
http://bit.ly/sKD4Ty
I'll guess your heat sink will do for most jobs, but I doubt it will withstand the more hardcore ones. Why not use a computer CPU heat sink with a fan next time? You can use one of the spare sections in the op-amp a thermostat, like I did, and easily dissipate 30 Watts through the thing.
Here is mine.
« Last Edit: December 20, 2011, 01:35:24 am by eternal_noob »
