Author Topic: Another Deutsch Connector Question  (Read 443 times)
Offline MarginallyStableTopic starter
« on: January 29, 2026, 09:02:07 pm »
Looking at Deutsch DTP connectors for another application. Rating are 25Amps per contact continuous at 125degC (no de-rating required).
I cannot find any data showing possibility of "pro-rating" for temps <125degC, or for short duty loads.
So I have a situation where ambient will be much less than 125degD, expect max load ~28amps for shorter periods, but continuous should be below the rated 25amps (circuit to be protected with a 30amp breaker).
Should I find a different connector, or what method can I prove that these are a suitable connector?
Thanks for any insight/thoughts
Offline Benta
Re: Another Deutsch Connector Question
« Reply #1 on: January 29, 2026, 10:18:28 pm »
Why do you think temperature is a parameter here?
25 A is continuous rating, I don't see an issue with 28 A over short periods.
« Reply #2 on: January 30, 2026, 10:14:48 pm »
I guess because the data sheet states "Max rated amps at 125degC continuous"
