Looking at Deutsch DTP connectors for another application. Rating are 25Amps per contact continuous at 125degC (no de-rating required).
I cannot find any data showing possibility of "pro-rating" for temps <125degC, or for short duty loads.
So I have a situation where ambient will be much less than 125degD, expect max load ~28amps for shorter periods, but continuous should be below the rated 25amps (circuit to be protected with a 30amp breaker).
Should I find a different connector, or what method can I prove that these are a suitable connector?
Thanks for any insight/thoughts
