Took some patience, but I built this "zinc negative resistance oscillator" after Nyle Steiner's design. (sparkbangbuzz.com)
This is a homemade tunnel diode amplifying device that works well for radio frequencies well into the higher frequencies, but apparently can also do audio to some extent.
(The metal working, of course, was done outside and with appropriate protection from heat, sparks, and fumes. Zinc fumes, I have read, are not good to breath.) I found the piece that worked best was a strip of galvanized sheet steel that was scorched pretty fast in a hot flame until white hot sparks were jumping, and quenched in water while still red hot. The catswhisker is just a piece or 22 gauge copper wire cut at an angle for a semi-sharp point. I pressed that point through a small disk of plastic so it stuck through about 1/8", and put some Duct Seal on the back of the disc for a little weight. This way I can pick up the whisker by its little connector wire (a single copper strand from and old stranded lamp cord) and set the tip in different places--or drag it gently--until I got a bit of oscillation on the scope (more than the damped wave you get when it makes and breaks contact). Then the potentiometer was adjusted for stable oscillation.
I changed the power supply slightly from Mr. Steiner's design to give more current control. I had no luck with the website's exact power supply design.
By the way, I found Steiner's zinc detector diodes both easy to make (much easier than the oscillator) and excellent performers.
cheers
Rob
Checking for gain by putting it in self oscillation at about 1.4 MHz. I used an AM broadcast band radio receiver to zero beat, and could pick up the radiation from this unit for as far as a bothered to carry the receiver.
Later I made a new one with different metals and a more refined holder.
I wanted to see how well this could amplify a modulated RF signal, so I set turned the voltage on this one just below the oscillation point and injected a tone modulated signal from the signal generator which was tuned to the same frequency as the resonant circuit, and played with the voltage level potentiometer a bit. I also cut the power and looked ate the signal output with the ZNO device both in circuit and bypassed. The scope clearly showed an increase of several times the input signal level when the batteries were connected.
I can see where this really could give a big signal boost to a crystal radio receiver.
In this picture it is running as just an oscillator, but quite strongly, at approximately 6-8 VPP and 800 kHz.
Edit:
I forgot to add that later still, I did try it successfully as an RF preamplifier for my crystal receiver.
