Author Topic: Arduino and logging over network with Node.js  (Read 3651 times)
Offline frenkyTopic starter
  • Country: si
    • Frenki.net
« on: October 06, 2012, 11:13:52 am »
Hi guys.
I've made a tutorial on how to use arduino with ethernet shield and Node.js server to make remote logging.
On Arduino I have a sketch which reads from analog port and sends udp packets to desired ip and port.
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
byte arduinoMac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress arduinoIP(192, 168, 1, 177); // desired IP for Arduino
unsigned int arduinoPort = 8888;      // port of Arduino
IPAddress receiverIP(192, 168, 1, 135); // IP of udp packets receiver
unsigned int receiverPort = 6000;      // port to listen on my PC
EthernetUDP Udp;
int sensorPin = A0; //define sensor pin
int sensorValue;
void setup() {
  Ethernet.begin(arduinoMac,arduinoIP);
  Udp.begin(arduinoPort);
void loop() {
  sensorValue = analogRead(sensorPin);//read sensor value from 0 to 1023
  byte valueInBytes[2] = {lowByte(sensorValue), highByte(sensorValue)}; //convert it to byte array
  Udp.beginPacket(receiverIP, receiverPort); //start udp packet
  Udp.write(valueInBytes, 2); //write sensor data to udp packet
  Udp.endPacket(); // end packet
  delay(1000);
On the other side I have a computer with Node.js and udp server to listen to udp traffic.
var dgram = require("dgram");
var server = dgram.createSocket("udp4");
var fs = require('fs');
var crlf = new Buffer(2);
crlf[0] = 0xD; //CR - Carriage return character
crlf[1] = 0xA; //LF - Line feed character
server.on("message", function (msg, rinfo) { //every time new data arrives do this:
  console.log("server got: " + msg.readUInt16LE(0) + " from " + rinfo.address + ":" + rinfo.port); // you can comment this line out
  fs.appendFile('mydata.txt', msg.readUInt16LE(0) + crlf, encoding='utf8');//write the value to file and add CRLF for line break
server.on("listening", function () {
  var address = server.address();
  console.log("server listening " + address.address + ":" + address.port);
server.bind(6000); //listen to udp traffic on port 6000
Node.js running:
Detailed tutorial is here: http://frenki.net/2012/10/remote-logging-with-arduino-and-node-js/
Have fun ;)
