Hi Everyone,
I'm working on a RF project. We need to implement low power communication between MCU-s, where MCU-s should be able to communicate P2P, and/or form a mesh network. We prefer ARM Cortex MCU-s and Keil development tools. We have to decide which protocol and which hardware to use.
Which one to use ZigBee or 6lowpan. What about power consumption difference between those two. ZigBee has to have Coordinator Node(CN) and Router Node(RN) must be actively listening all the time, while 6lowpan doesn't require CN and RN, and isn't actively listening.
We were looking at following hardware:
- Freescale KW0x - it has great output power (+17 dBm), but doesn't have any stack implementation for it
- Freescale KW2x - higher power consumption than KW0x, and no 6lowpan implementation
- STM32w - only stm32w108hb has active status, but has RAM size to small to run COntiki, has SMAC and rf4ce support
- TI CC2538 - can run Contiki, IAR required, only Zigbee Home support which isn't compatible with other zigbee standards
The hardware should have to have output power at least +7dBm or +8 dBm, and sensitivity as big as possible.
We don't need to use hardware mentioned above or have everything integrated on one chip, but we would like to avoid more expensive solutions like xbee.
Does anyone have a suggestion which hardware and which protocol to use? Does anyone have any experience building something similar? Any information would be useful.
Thanks in advance!
